I need to fix a 4x2 timber to a hollow brick wall for a small indoor/outdoor building project.
The timber will mainly support a light frame, but I would like the fixing to remain secure over time. I am considering concrete screws because they seem straightforward to install, but I am not sure whether they are suitable for hollow brick rather than solid masonry.
Would frame fixings or a sleeve-type anchor be a better option? Are there any particular problems with the screw ending up in a cavity instead of one of the solid webs of the brick?
I would also appreciate advice on washer size, pilot-hole drilling, and whether zinc-plated or galvanised fixings are preferable if the wall is exposed to some moisture.
