banging pipes....nightmare!!! please help
leonbrydon
by leonbrydon » Fri Mar 27, 2009 9:00 am
Can anyone help,
when anyone uses the shower or turns the water on in my house, the pipes in my bedroom bang until a short time after the shower or tap are turned off, this is a nightmare when someone is up early. can anyone give me any solutions to this, maybe changing the pressure in the system etc.many thanks
by htg engineer » Fri Mar 27, 2009 2:44 pm
Close mains stop tap slightly, clip and lag piepwork to limit vibrations.
htg
rosebery
by rosebery » Fri Mar 27, 2009 7:38 pm
and if that doesn't entirey solve it fit a shock arrester. Note that it is important that this water hamer problem is dealt with. The shockwaves can be so severe as to cause fittings to fail in time - then you've got a flood to deal with.
It is currently Wed Apr 23, 2025 11:23 pm
