by stoneyboy »
Wed Jun 24, 2026 11:18 pm
Hi jeffdorling,
Images 1,3 and 4 look like brickwork movement you should trace the cracks along the brickwork and see if there are vertical cracks going down below ground level. If there is it may be caused by foundation problems.
Image 2 is where a poor job has been carried out re-pointing the mortar line.
Image 5 is a combination of poor re-pointing plus brickwork movement.
Suggest you get a structural surveyor in for a diagnosis
