For the past couple of weeks my central heating pump has not shut down for several hours after the heating has turned off.
As the pump is in a cupboard in my bedroom this is causing me sleepless nights.
After doing some research I thought the problem might be a faulty overrun thermostat however as far as I can tell the pump is not wired to an overrun thermostat. How can I tell if it is wired to an overrun thermostat? If it is not wired to an overrun thermostate is there a fault that could result in the pump continuing to run after the boiler shuts down?
thanks for your help
