Large crack appeared under flat roof ... used to be the coal shed
Helensd
by Helensd » Tue Aug 12, 2025 12:25 pm
Hello. I moved into a rather run down 50s concrete block house. There used to be an unattached coal shed but this has long been converted into an extra room. A large crack has appeared - see photo. Is this structural, or can I just plaster over it. Many thanks to anyone willing to help. Best wishes, Helen.
Re: Large crack appeared under flat roof ... used to be the coal shed
by stoneyboy » Tue Aug 12, 2025 11:05 pm
Hi helensd,
Being a coal shed it’s likely to have single skin brick walls and a concrete roof, there will always be movement between these two. Suggest you fill the crack and see whether is reappears.
Regards SB
Helensd
by Helensd » Tue Aug 26, 2025 1:08 pm
Hi helensd,
Regards SB
Thank you. Helen.
It is currently Sun Aug 16, 2026 7:43 pm
