Garden Walls
chrisjlye
Garden Walls
by chrisjlye » Thu Mar 27, 2008 1:17 pm
I am thinking about leveling a section of my garden and building a wall to essentially form a rasied bed where once there was a continuous slope. It will be no taller than 2-3ft tall with some steps (made from decking steps) in the middle. I am assuming the wall will be split into 2 L-shaped sections. How deep/wide will the trench have to be? And the concrete bed?
I am also assuming that it will have to be double skinned - is this a fair assumption? Therefore should both skins be brick or can the rear be concrete block? Do the skins have to be bound together? If so how?
Many thanks,
Chris
ALDA
by ALDA » Fri Mar 28, 2008 10:47 pm
CHRIS,
SEE PREVIOUS GARDENING POST TO THIS ONE FOR GUIDELINES AND IF YOU NEED FURTHER ADVICE GET BACK TO ME.
ALDA.
grooverider991
Re: Garden Walls
by grooverider991 » Mon Mar 31, 2008 8:44 pm
HI Chris,build the wall in 9 inch brickwork and dig the footings to a minimum of 400mm deep and 500mm wide using a concrete mix of 5 to 1 ratio[quote="chrisjlye"]I am thinking about leveling a section of my garden and building a wall to essentially form a rasied bed where once there was a continuous slope. It will be no taller than 2-3ft tall with some steps (made from decking steps) in the middle. I am assuming the wall will be split into 2 L-shaped sections. How deep/wide will the trench have to be? And the concrete bed?
Many thanks,
Chris[/quote]
It is currently Sat Nov 23, 2024 7:21 pm
