Stain keeps appearing through paint...help!
sleepysunday
by sleepysunday » Fri Mar 28, 2008 5:07 pm
We had a leak in our roof 18 months ago and since then have had a new roof and the wall has dried out in our bedroom. I have scraped away all the old paint and some plaster and have used an eco friendly stainblock on the area which normally requires 2 coats, however every time i put it on the stain marks come through.
Has anyone got any suggestions? I need to finish painting this room asap and know the wall is completely dry.....
Sally
JIMLLFIXIT
Re: Stain keeps appearing through paint...help!
by JIMLLFIXIT » Fri Mar 28, 2008 10:11 pm
FIRST TIME HERE SO SORRY IF NOT IN RIGHT PLACE . STUBBORN STAINS USE A COAT OF PRIMER OR EVEN GLOSS .
Sally[/quote]
the paint pot
by the paint pot » Sat Mar 29, 2008 1:41 am
[quote="JIMLLFIXIT"]FIRST TIME HERE SO SORRY IF NOT IN RIGHT PLACE . STUBBORN STAINS USE A COAT OF PRIMER OR EVEN GLOSS .
Sally[/quote][/quote]
hi the best stain block is international stain block you can get it fron b&q or homebase e.c.t as you need a stain block with a high pigment content.
most eco frendley paints a water base witch allows the stain to penatrate each coat of paint
hope this helps
It is currently Tue Nov 26, 2024 6:09 pm
