1500 Watt Lawn Mower
lee_p
by lee_p » Fri Mar 28, 2008 8:14 pm
Can you tell me if running a 1500 Watt lawn mower is ok on a 5 amp fuse it is a main fuse box feed into garage with a 5 amp fuse in it ( 1 5 in main box 1 5 in garage).
Lee
by ericmark » Sat Mar 29, 2008 6:27 am
Simple answer No. 1 amp @ 230 volt = 230 watt there for 1500 Watt = 6.52 amp and this does no allow for starting currents or power factor so most likely will need full 13 amp. Some motors do have soft start and you may get away with lower size fuse. Trail are error only real way to know but min will be 7 amp.
lee_p
by lee_p » Sat Mar 29, 2008 7:44 am
Thanks Eric back to hunting for a new lawn mower max 1000 watt prefably with soft start
Lee
nitro23456
by nitro23456 » Sat Mar 29, 2008 7:47 pm
get a petrol one, much better anyway!
It is currently Sat Nov 23, 2024 4:46 am
