Immersion
geoffm
Immersion
by geoffm » Mon Mar 31, 2008 9:42 am
I have an immersion heater screwed in to the top of the cylinder. Even with the power to the immersion switched off there is a high pitched alarm coming from it. This tends to happen when I switch the central heating or the shower on
What is causing this?
chris_on_tour2002
by chris_on_tour2002 » Mon Mar 31, 2008 4:06 pm
are you sure its coming from the immersion heater? i'm not aware of any that have alarms on them. do you have a carbon monoxide detector in the cupboard? or perhaps a mouse has taken up residence....
geoffm
by geoffm » Mon Mar 31, 2008 9:34 pm
its definitely coming from the top where the immersion is and it is red hot to touch and so is the pipe into the cylinder and that is with the power and the central heating all switched off
geoffm
by geoffm » Tue Apr 01, 2008 8:20 am
my mistake, I couldn't isolate the high pitched whine in the cupboard but now I am sure it is coming from the pump/motor area at the side of the cylinder, perhaps the motor is on the way out
It is currently Tue Jan 07, 2025 10:09 pm
