by Jeffmo »
Mon Apr 23, 2007 6:58 pm
as far as i am aware there can only be a recommendation to rewire , unless you get an installation checked by a qualified electrician in which case they should do a full test of the wiring systems in your house ,and they are obliged to and legally bound to note the requirements of the wiring , I would suggest that the wiring would probably need replacing , however depending on type of wiring ie rubber or pvc and the fuseways and switchgear will make the electricians decision very easy . If you are concerned at all get an electrical survey done and get the price taken off the house its worth a barter the average 3 bed semi rewire would probably cost you about £2,500 to £3,500 pounds , so try and sell this to the vendor . Regards and good luck Jeff
