Plumbing
ollie49
Plumbing
by ollie49 » Wed Apr 02, 2008 12:21 am
Why is the hot cylinder expanding and cracks and bumps appearing in the polystern legging covering the cylinder? :cry: .
by htg engineer » Wed Apr 02, 2008 7:53 pm
If the hot water to the taps is still ok - for example not too hot or hotter than normal - then it is probably just with age and the constant heat. You can buy cylinder jackets for insulation.
If you think the water is too hot or to check - try turning down the cylinder stat and use a thermometer to check the stat is working and the water temperature does drop. This will rule out excessive heat (over heating) being the problem.
It is currently Wed Jan 08, 2025 6:10 pm
