heating
hud
heating
by hud » Wed Apr 02, 2008 6:45 pm
hi,some of my rads are heating at the top and down the sides but not in the middle ,what wll the problem be and how can i fix it myself?thanks .
nitro23456
by nitro23456 » Thu Apr 03, 2008 10:53 am
most likely sludge build up inside the rads. difficult to say 100% with the info provided though.
How old is your system and has it been flushed recently?..... if not for years it is likely sludge build up and the remedy would be draining and power flushing the system.
if it is one or two rads you could isolate them, take them off and hose pipe them through in the garden until water is clear. However sludge is like a spider - where there is one there is more.
hope that helps.
chris_on_tour2002
by chris_on_tour2002 » Thu Apr 03, 2008 1:04 pm
probably a build up of sludge, eliminate this first. remove offending rads, flush out with a high pressure hosepipe and replace. see if this makes a difference. if so, add a sludge remover/inhibitor. if its severe it may need a power flush by a professional.
It is currently Wed Jan 08, 2025 5:56 pm
