cast soil pipe
7 posts   •   Page 1 of 1
frog77
cast soil pipe
by frog77 » Thu Apr 03, 2008 12:01 pm
hi hope you can help me what is the best way off cutting a section off the old cast soil pipe i need to replace a section as i have a leak
chris_on_tour2002
by chris_on_tour2002 » Thu Apr 03, 2008 1:48 pm
hack saw. dont try to grind it, cast can shatter.
by htg engineer » Thu Apr 03, 2008 3:54 pm
Angle grinder is the easiest for access, don't try to cut first cut as the final cut. As you do get some where it'll break where it hits weak spot.
It's always best to cut abit longer so that you have a second chance if needed (for example don't try to cut level with a wall or floor because if it's breaks your knackered).
frog77
by frog77 » Thu Apr 03, 2008 10:10 pm
[quote="chris_on_tour2002"]hack saw. dont try to grind it, cast can shatter.[/quote]
the problem is the soil pipe is tight in a corner couldnt get in to cot all way through with a hack saw will an angle grinder do it thank you
ALDA
by ALDA » Sat Apr 05, 2008 12:08 pm
Would a reciprocating saw help?
Failing that, rap a hacksaw blade in a rag to protect your hands and carefully proceed with cut.(If possible try to cut all the way round the out side of the pipe first without actually breaking through).
chris_on_tour2002
by chris_on_tour2002 » Sun Apr 06, 2008 10:08 am
if you must use an angle grinder, i'd suggest wearing body armour, a helmet and a visor! if its in a corner and it shatters (either the cast iron pipe or the cutting blade) then the shrapnel is going to get thrown straight at you. take great care when cutting cast iron with a grinder.
thedoctor
by thedoctor » Sun Apr 06, 2008 10:55 am
Replace the cast iron with plastic pipe. Apart from costing you a little more you will be able to do this in less time that cutting the cast.
It is currently Thu Jan 23, 2025 1:58 pm
