Y & S plan
geordieblue
Y & S plan
by geordieblue » Fri Apr 04, 2008 8:54 pm
in basic terms please explain what "Y" & "S" plan is all about. need help!!
by ericmark » Sun Apr 06, 2008 5:33 pm
You can have W, S, Y, and C plans. The Honeywell site has details of all plans.
The S uses two motorised valves one for domestic hot water the other for central heating and lends itself to expanding into S plus with zone heating.
The Y uses a single valve with a mid position but is not as easy to expand to add zones and you can’t normally select on a programmer central heating only although why one would want to I do not know. Both central heating and hot water can run together.
The W plan very like Y plan but either hot water or central heating not both together
The C plan domestic hot water is not pumped.
It is currently Mon Jan 06, 2025 2:23 pm
