How best to paint a sooty surface
mortod
by mortod » Mon Apr 07, 2008 2:55 pm
I need to paint what used to be a (wood?) boiler room which over the years has accumulated a thin layer of black on the brick walls and rendered ceiling. I have cleaned as best I can - no loose stuff, but still pretty black.
How best to tackle this? Should I seal/stabilise first with PVA or some other product? Should I then use indoor immulsion or a masonary paint? I did just put a dab of exterior masonary paint onto the surface and it seemed to take OK. The quality of finish is not important as is only to be used as a store cupboard.
Any advice appreciated.
chris_on_tour2002
by chris_on_tour2002 » Wed Apr 09, 2008 10:36 am
if the surface is clean and there is no more loose dust then paint should take ok. use a good quality primer first, such as bullseye which also has stain blocking properties - staining bleeding through is likely to be a bigger problem than getting the paint to stick.
It is currently Wed Dec 04, 2024 8:55 am
