leaking cistern from push button flush
steve edwards
by steve edwards » Mon Apr 07, 2008 3:59 pm
Hi I have a 2year old leaking toilet I cannot see how to remove the top from my cistern (the top houses the push button flush) I am sure it must be quite simple maybe I am "Thick" [color=blue][/color][url][/url]
by htg engineer » Mon Apr 07, 2008 7:18 pm
There's sometimes a ring around the buttons, try to unscrew anti-clockwise.
Skids
by Skids » Mon Apr 07, 2008 10:55 pm
Hi steve,
Do not touch the ring!
Gently prise up the flush buttons with the point of a sharp knife (push the tip of the knife slightly below the top of the button into the side and lift it up) remove both buttons.
In the well you should see a plastic flat screw, undo with a large screwdriver and the cap will come off.
Remove the lid.
Regards
Skids
by htg engineer » Tue Apr 08, 2008 3:02 pm
Skids - do not touch the ring ????
I have worked on may where you have to unscrew the ring to remove the cistern lid.
So how do you suggest i remove the cistern lid from this type of cistern in future ? look forward to your reply - cos it'll have to be magic.
It is currently Wed Jan 08, 2025 6:04 pm
