I have a baxi 105e condensing boiler.
About 3 mths ago a B/G engineer came an replaced the diaphram, (think thats what it was called)since then the pressure has been really irratic sometime running at 3.5.
If that wasn't bad enough, everytime the hot water was used the boiler made a terrible noise (which has subsided quite alot).
But the annoying thing is, when the heating starts up, the water drips out of the overflow pipe. This in turn has started to to drip though an air vent and has started to drip inside rather than out. :(
Have had a B/G service engineer out again who tells me my system needs flushing and they do it for £650. :shock:
He said all the trouble i'm having was because of sludge and debris in the system, yet when he tested it the water was clear.
The whole system is 4 yrs old, does it really need flushing?? the first engineer said no..
Any advice would be appriciated.
