Powershower
dalila
Powershower
by dalila » Thu Apr 10, 2008 5:13 pm
Power shower installed 4 yrs ago. Shower not working properly. Gives hot water only when turned to maximum. Please advise
by htg engineer » Sat Apr 12, 2008 9:49 pm
Filters blocked maybe ? limescale blocking the filters on the hot water inlet will mean there's more cold water getting through than hot.
Strip down and clean/renew the filters, see if there's any improvement.
chris_on_tour2002
by chris_on_tour2002 » Sun Apr 13, 2008 9:07 pm
i had a similar problem with a power shower a while ago. turned out that the non return valve in the unit had gunked up and was sticking shut. no flow, so the pump wasn't being triggered. might be worth investigating as well.
It is currently Wed Jan 08, 2025 6:29 pm
