pvc window and door directly next to each other
pate_luv
by pate_luv » Mon Apr 14, 2008 1:21 pm
I am building a new extension and have a window and back door directly next to each other, i.e. their frames are touching. Can i attach the two frames together or must i get a purpose built window and door unit?
winger
by winger » Mon Apr 14, 2008 7:20 pm
get a door and a window and there is section you can get from the supplier that snaps into them both . You will also need safety glass for the window aswell as it will be less than 300mm from the door (safety glass in doors is standard)
It is currently Sat Nov 23, 2024 3:52 am
