urgent help required regarding plasma gasfire
7 posts   •   Page 1 of 1
vw754
by vw754 » Mon Apr 14, 2008 9:56 pm
Hope someone can help....im having my existing chimney bricked up/plastered......and im thinking of getting a plasma Gas fire, wall-hung flueless. I wanted to know if its ok in a 11' x 12' room?
I wont be using it much at all (got central heating) only on odd occasions. A friend of mine said you may not be able to have it in a room that small,is he right ?
The gas fire is from screwfix at £399.99 Below is what i have from screwfix catalogue.........
Cheshire Flueless Gas Fire
flueless gas fires require a minimum room size and purpose provided ventilation of 100cm². Refer to product specification.
Variable Heat Output 2.0kW High - 1.0kw Low
Wall Mounted
Catalytic Converter
Oxygen Depletion Sensor
Flame Failure Safety Device
rosebery
by rosebery » Tue Apr 15, 2008 1:00 am
You may be very lucky to get an opinion. I know a lot of gas fitters who won't touch the things.
Sorry.
muttley
by muttley » Sat Apr 19, 2008 8:34 am
[quote="rosebery"]You may be very lucky to get an opinion. I know a lot of gas fitters who won't touch the things.
Sorry.
Cheers[/quote]
Dont install these,they are rubbish
rosebery
by rosebery » Sat Apr 19, 2008 3:02 pm
Mutley
That's really what I was trying to say without being brutal.
vw754
by vw754 » Sat Apr 19, 2008 3:57 pm
HI,Thanks for the info,can you explain more when you say that there rubbish?
in what way?
rosebery
by rosebery » Sun Apr 20, 2008 9:11 am
vw
The reason I said "I know a lot of gas fitters who won't touch the things" is because they think they are dangerous and don't want to be associated with them.
Does that give you a better clue?
griffo
by griffo » Thu Jun 12, 2008 10:44 pm
By Rubish he probably means potentialy dangerous! They have a Catalitic type converter in them to clean up the products of combustion and not poisen you.
Your car also has a Catalitic convertor, would you back your car up to your lounge pipe the exhaust in and run it fot a couple of hours?
Dont fancy that myself.
It is currently Sat Nov 23, 2024 1:21 am
