Relocating a Socket
striker
Relocating a Socket
by striker » Sat Apr 19, 2008 7:49 pm
Hi, I am going to knock down an internal block wall which connects a utility room to the kitchen. This wall is not a load bearing wall. On the wall is a chased in double socket kitchen side, and right behind the double socket, a trunked single socket which is a spur on the utility side. I need to relocate these to a party wall not too far away from the consumer unit which I will be doing before I knock the wall down.
What I was thinking of doing was disconnecting the T&E from the consumer unit and using this length (from the first socket it is connected to) for the new double socket and then installing some new T&E from the consumer unit to the new double socket. However, I need to know what I can do with the old cable. Can I feed these both into a junction box under the floorboards up stairs where the T&E for both the old socket currently lie. The junction box would be accessible by pulling up a little carpet and a small floor board.
More importantly, would this be notifiable under part p building regs?
BLAKEY1963
Re: Relocating a Socket
by BLAKEY1963 » Sun Apr 20, 2008 11:12 am
[quote="striker"]Hi, I am going to knock down an internal block wall which connects a utility room to the kitchen. This wall is not a load bearing wall. On the wall is a chased in double socket kitchen side, and right behind the double socket, a trunked single socket which is a spur on the utility side. I need to relocate these to a party wall not too far away from the consumer unit which I will be doing before I knock the wall down.
More importantly, would this be notifiable under part p building regs?[/quote]
STRIKER
If the kitchen socket is currently on the ring and the the utility
socket is spurred off it, then once the utility socket could be disconnected
( safe isolation proceedures first ) this would leave the two ends of the ring main . once pulled up in to the void beneath floor boards
these could be put into 2 separate 30 amp joint boxes to extend the two
legs of the ring main to meet your new position for this socket.
as u say u will make provision for these joint boxes to be accesable.
i would get in an electrician to check the work afterwards.
part p comes in with kitchen work and he can advise accordinly
BLAKEY1963
by ericmark » Sun Apr 20, 2008 11:47 am
You say Kitchen so special location so yes Part P but far too complicated to work out for others what is and what isn't Part P better to follow links in Projects and look for yourself. As to junction boxes, these must be accessible.
“What I was thinking of doing was disconnecting the T&E from the consumer unit and using this length (from the first socket it is connected to) for the new double socket and then installing some new T&E from the consumer unit to the new double socket.â€
It is currently Mon Jan 06, 2025 9:32 am
