Toilet trouble
6 posts   •   Page 1 of 1
nic86ola
Toilet trouble
by nic86ola » Sun Apr 20, 2008 12:25 am
Have noticed over past couple of days that when the toilet is flushed, a short while after a loud chugging noise is heard and the toliet shakes slightly. Any ideas what the problem could be? How to fix it?
Thanks!
nitro23456
by nitro23456 » Sun Apr 20, 2008 7:28 am
Sounds like ablockage in your waste.
nic86ola
by nic86ola » Sun Apr 20, 2008 9:24 pm
How do you recommend we rectify this problem? Is a plumer needed? Would it be an expensive job if so?
rosebery
by rosebery » Sun Apr 20, 2008 9:48 pm
Is it the waste making the noise or the refilling process? Could be either and it's a different solution for each.
Dave From Leeds
by Dave From Leeds » Mon Apr 21, 2008 1:10 am
An easy way to check for the answer to rosebery's question is to turn off your mains water then flush the toilet. If the noise doesn't occur it suggests the filling system. If noise still present then it's likely to be the waste.
nic86ola
by nic86ola » Mon Apr 21, 2008 10:26 am
Does anyone have any idea how to rectify the problem if due to the filling process? Is a plumber required? Thanks
It is currently Thu Jan 09, 2025 6:33 am
