Fixing curtain rails to old walls
Carlos_dp
by Carlos_dp » Mon Apr 21, 2008 10:09 am
Hello,
I've tried drilling and screwing rawplugs into a a plastered wall for a curtain rail.
The house and plaster is pretty old, I've just had the room skimmed and painted. When I drill into the plaster, I get past the skim to the base plaster that is merely dust (mostly) and won't hold a plug. The wall beyond is stone (at least it is on the outside) so drilling isn't much use.
How do I get the curtain rail up ? If I use a baton, should I try to nail it or use no-more-nails etc....will this simply pull all the plaster off ?
Any helpful suggestions ?
ALDA
by ALDA » Mon Apr 21, 2008 8:38 pm
YOU NEED TO DRILL DEEPER HOLES INTO THE MASONARY AND USE LONGER SCREWS TO SECURE.
It is currently Fri Jan 10, 2025 3:09 am
