cable tracking
geffers123
cable tracking
by geffers123 » Mon Apr 21, 2008 1:03 pm
what is the best way of tracking a cable from one end of the house to another? with the power off can i put it to earth at one end & use an audible meter at the other end? if so what meter do i need? (on a budget keep it cheap)
kbrownie
by kbrownie » Mon Apr 21, 2008 4:43 pm
geffers123,
You need a something to connect the cables together i.e. connection block. cost penny's
and a meter to test continuity. A multimeter will do that, about a tenner.
Then connect each conductor at a time to each other, Phase to earth, neutral to earth and phase to neutral. one at a time and test at the other end.
Regards
KB
It is currently Sat Nov 23, 2024 11:24 am
