Fixing Shelves to Plasterboard Walls
gearyt
by gearyt » Tue Apr 22, 2008 11:22 am
I have tried fixing floating shelves to my plasterboard walls using redidrive plasterboard fixings. There are 10 holes for screws on the shelve brackets. As I was using redidrive fixings the screw holes on the bracket were to close so I could only use 5 of the holes. Unfortunately these did not hold the shelves with books on them. I now have a number of holes in the wall that I have filled with polyfilla.
I have two questions;
1. As the redidrive plasterboard fixings were not strong enough should I be using hollow wall anchors. The shelves can take up to 15kg.
2. Can I re-use the holes now that I have put polyfilla in them or is it better to re-locate the holes?
Thanks for your help.
Joiner_Mike
Fixing your shelf
by Joiner_Mike » Tue Apr 22, 2008 10:54 pm
You say you wall is plasterboard. Is it what is called dot and dab where plasterboard is stuck to a brick wall or is it a timber wall?
You are probably best now screwing into new holes. If it is a rick wall behind just get a longer drill bit and screws and plug and screw directly into the brick.
It is currently Sun Dec 22, 2024 8:43 pm
