Very very dumb question
taitai
by taitai » Thu Apr 26, 2007 1:12 pm
I don’t know much about plumbing, so apologies for the this stupid question.
Why do the British use an internal cold water tank system, or why can’t I connect the mains directly to the pipe which comes out of my water tank and bypass the water tank all together.
I know this is like asking why do the sun rise but I can’t see this great invention in other European countries. (I don’t see this system in modern city flats either)
cueball
by cueball » Tue May 01, 2007 11:15 pm
in an emergency you will have a fresh store of cold water and the height of the tank allows for pressurised water to the hot water taps
DONFRAMAC
Very very dumb question.
by DONFRAMAC » Wed May 02, 2007 2:13 am
The use of showers for bathing in this country has been late in reaching these shores, due in part to cost of installing both a bath and a shower;-- so a thin-wall large volume tank of hot water, fed by low-pressure cold water from a header-tank in the loft was for most people, the only source of hot water, often heated by a "back-boiler", behind the coal fire. Electric showers use expensive electricity, and central heating has been beyond the financial means of the masses until the advent of double-incomes, which now seems to be the only way people can afford to purchase a home. Another point to be made is that drinking-water cannot be drawn from the tank in the loft, due to the risk of legionnaire's disease, etc.
dave p
Re: Very very dumb question
by dave p » Sat May 05, 2007 11:26 pm
You can blame the germans for that one (only joking) during the war it was better to use cold water storage cisterns as this would give famalies 24 hrs of bathing/toilet water if the supply was damaged. it is also a good idea if you are in a low water pressure area as only the kitchen sink is under mains pressure.
you can turn your system into a direct system but before you do get tests done first to see if your supply can cope. you only have to read all the "low water pressure" problems on this site to see the that even though its an old design it works well.
wessy
by wessy » Mon May 07, 2007 2:49 pm
installing wall mounted bath taps
It is currently Fri Nov 22, 2024 10:37 pm
