by Joiner_Mike »
Thu Apr 24, 2008 4:47 pm
There are 2 main ways in which you can tackle this problem.
The first is to lay a piece of underlay that you are going to use on the floor next to the casing. Then get a piece of laminate flooring that your using and lay it face down. Now run your saw flat on the ack of the laminate and cut the casing out. So when you fit the floor it will run under the casing. (This i s how i do it)
or you can buy a small profiler. Has loads of pins in a line. Then when u get to the point near the door you push these pins in to the casing so you get a profile of the casing, transfer it onto your laminate and cut with a jig saw. Then fill the small gap around the casing with flexible filler.
Hope this helps
