pva for browing?
chris_on_tour2002
pva for browing?
by chris_on_tour2002 » Mon Apr 28, 2008 1:40 pm
hi,
plastering my bathroom which is currently exposed brickwork. for the first time ever i have used browning. dont know why, i normally use bonding but i thought i'd use it as it is on external wall.
i pva'd the walls then applied the browning when the pva was still tacky. then i read on the bag that no bonding agents should be used! oh dear... is my browning going to fall off? it has cracked up a little here and there as its dried but it seems to be perfectly sound so far.
i have to put another layer of browning on and rule off ready for skimming. i am then going to tile which will of course add weight. add to this the moisture element (being a bathroom and all) should i strip it off and start again with bonding? does one normally pva with browning? i just made the assumption without checking.
Briggy
by Briggy » Mon Apr 28, 2008 9:40 pm
Hello Chris, i hate to say this , but browning should be applied to a mechanical key, then just dampen, (no bonding agents) also browning doesn't like to much exposure to moisture either, Ha Ha,(bp recommedation not mine!) i don't use it anymore if i can help it! i prefer hardwall. Hope this helps! Regards.
chris_on_tour2002
by chris_on_tour2002 » Mon Apr 28, 2008 11:58 pm
thanks briggy - thats exactly as i feared. think i will strip it off and start again with a substrate more familiar. don't know why i suddenly decided to use browning anyway, i've never used it before. stick to what you know.
what exactly constitutes a mechanical key? brickwork? cement render scratch coat? or just any unbonded background? clarification would be gratefully received!
Briggy
by Briggy » Tue Apr 29, 2008 8:01 pm
Hello again, it's just fancy talk for raked out brickwork or running a scutch hammer over it! Regards!
It is currently Fri Nov 22, 2024 2:11 pm
