Water stains on Enamel Bath
doug.graham@virgin.net
by doug.graham@virgin.net » Fri May 02, 2008 9:25 am
Does anyone know of a way to remove the blueish green stain that results from a tap dripping on a enamel bath over a protracted period of time.
Presumably it is some sort of copper deposit.
help would be appreciated
Doug
chris_on_tour2002
by chris_on_tour2002 » Fri May 02, 2008 4:29 pm
it is a copper deposit and unfortunately as copper is a reactive substance its probably eaten away at the enamel. there are specialist companies that can do it and re-enamel the bath at the same time. there is a well-known national franchise that do this but the name escapes me at the moment. prices are fairly reasonable.
ALDA
by ALDA » Fri May 02, 2008 6:35 pm
APPLY MURIATIC ACID.
OR
TRY RUBBING WITH HALVED LEMONS IF STAINING IS NOT TO SEVERE.
It is currently Tue Dec 03, 2024 12:36 am
