Removing a double socket
CPShines
by CPShines » Fri May 02, 2008 4:31 pm
Hi All, novice DIYer here, I hope you can help :)
I want to remove a double socket from our bedroom. If it turns out to be on the ring main rather than on a spur, I was thinking of disconnecting the two ring main wires from the socket, taking them back down under the floorboards, and joining them with either
screwfix.com/prods/12534/Electrical/Cable-Accessories/Waterproof-Cable-Joints/Waterproof-Cable-Joint-IP67 [/url]
or Screwfix.com/prods/13013/Electrical/Cable-Accessories/Junction-Boxes/Standard-Junction-Box-30A-3-Terminal
I'd then make a small access panel in the floorboard and carpet over it. Am I on the right track? Many thanks.
by ericmark » Sat May 03, 2008 4:57 am
Nice simple answer Yes
CPShines
by CPShines » Sat May 03, 2008 1:42 pm
That's good to know. Thanks very much :)
It is currently Fri Jan 17, 2025 1:50 pm
