by Andynclaire »
Sun May 04, 2008 11:50 pm
[quote="htg engineer"]Vent pump and open automatic airvent.
If it's leaking outside, what is the pressure set to ? should be between 1.0 and 1.5 bar.
If that is where the pressure is set to, strip out and clean the pressure relief valve, if that doesn't work, the pressure relief valve needs replacing.
Did you drain the system via the pressure relief valve ? not the best way as they do leak sometimes - always drain from a drain point on the pipework or from a radiator.[/quote]
Thanks very much for the advice, turned out to be a duff PRV as you had suggested.
Replaced and filled and bled, no probs now. Thanks again!!
