Can I fit a new hand basin waste to a toilet soil pipe?
7 posts   •   Page 1 of 1
Karen777
by Karen777 » Fri May 02, 2008 10:33 pm
My loo is separate to the showerroom and does not have a sink. So, I was hoping to fit a hand basin and connect the waste pipe to the toilet waste. Is this possible? If so, any top tips would be welcome.
Thank you
Karen777
TerryH
by TerryH » Sat May 03, 2008 10:13 am
Karen,
Yes, you can....... here's the 'but'.
You will have to remove the w/c and fit a new pan connector with a 'boss' of the appropriate size on it. This is a modified pan connector with a small connector on top of the bend that allows this type of connection.
mcalpineplumbing.productlist.asp
Have a look at the above address and you should see what I mean.
I hope that helps.
TH
bobplum
by bobplum » Sat May 03, 2008 6:56 pm
hi
could karen777 just buy a strap on boss connect with boss on the top and bring in the waste pipe from the top save messing around?
all thoughts welcome
bob
Karen777
by Karen777 » Sat May 03, 2008 9:39 pm
Thank you Terry.
I am sure that disconnecting a loo in a tenement building will be a 'fun' experience... I will be sure to get my boyfriend involved in the work!
TerryH
by TerryH » Sun May 04, 2008 7:56 pm
Bobplum,
That sounds like a good idea and saves all that messing about. I guess a boss would fit just as well to a 4" pan connector as it would to a 4" soil pipe.
Nice one!
TH
rosebery
by rosebery » Sun May 04, 2008 10:08 pm
Whatever you do make sure you fit an anti-syphon trap!
Karen777
by Karen777 » Sun May 04, 2008 10:43 pm
Thank you for your help.
I have looked into both options and have looked closely at the soil pipe and the space surrounding it and I think that there isn't enough room for the strap on boss so will do the other option. Thank you very much for the guidance.
Karen777
It is currently Fri Nov 22, 2024 11:28 pm
