Condensation prob's what type of dry lining?
pthebs
by pthebs » Sat May 03, 2008 11:31 am
I have a 1930's house with 11" thick solid breeze block walls and 9 foot ceilings. In the winter condensation becomes a nightmare, and leaving the windows constantly open turns the house into a draughty fridge.
What is the best type of dry lining I can fit for this application?
If I use the thermal board type what thickness is most economical?
kbrownie
by kbrownie » Sat May 17, 2008 4:42 am
Hi pthebs,
I can see you posted this a couple of weeks back, so you may have already sorted problem out.
As you have had no response to this post. I guess it may be because it's an odd question. I don't think dry-lining would sort your condinsation problems out, I'd be thinking of putting some air bricks in through the walls before I dry-lined, creating a bit of ventilation
Regards
KB.
It is currently Sun Nov 24, 2024 4:42 am
