Noisey pipes
orlando
Noisey pipes
by orlando » Sat May 03, 2008 11:40 am
my cold water pipes are very noisey and vibrate when cistern is flushed,opening a cold water tap stops the noise,Please help!!
by htg engineer » Sat May 03, 2008 4:00 pm
check the ball valve, it may not be opening fully causing the vibration through the pipes, strip down clean and renew washer and it should be ok.
It is currently Thu Oct 31, 2024 7:24 pm
