Maintaining concrete paths
oldseth
by oldseth » Mon May 05, 2008 2:35 pm
My house is 35 years old and is built on a sloping site. The concrete paths all around the house abut the building and are showing their age with gaps opening up where the paths meet the walls. Cracking has also occured where the levels change. I am concerned that water is draining through these gaps and in some cases the water now drains towards the building instead of away from it. Any suggestions as to how best I can repair the problem?
Steve the gas
Path cure
by Steve the gas » Tue May 06, 2008 6:08 am
Quick fix is clean and rake out all cracks (make bigger if nec) then use a sealant in joint if small or re-point with strong mortar if large.Long fix is rip it all out and re-lay whilst using a DPM, Ties and expansion joints say every 1.8 metres. HTH
TheDoctor4
Help from DIY Doctor!
by TheDoctor4 » Mon Jul 26, 2010 8:56 pm
For up to 5 FREE quotes from trusted, vetted and insured tradesmen in your area visit the DIY Doctor Find a Tradesman page: https://www.diydoctor.org.uk/find_tradesmen/
It is currently Mon Dec 23, 2024 8:52 am
