Kitchen hot water tap won't stop!
Kenny123
by Kenny123 » Thu May 08, 2008 5:02 pm
I have a mixer tap in the kitchen and the hot water tap will not turn off. I have turned off stop cock at hot water tank and have taken tap off cold water side to see if I can notice any difference but I cannot see any. I am looking at a wee brass coloured 'cog' thing and wonder whether I unscrew the large nut at the bottom of the assembly and replace whole thing or is it something simpler???
Please help!
Kenny.
ALDA
by ALDA » Fri May 09, 2008 2:14 pm
KENNY123,
THE BRASS COG THING IS THE END OF THE TAP VALVE SPINDLE!
THE LARGE NUT IS THE VALVE BODY INTO WHICH THE VALVE SPINDLE ASSEMBLY IS INSERTED!
IT IS LIKELY THAT THE VALVE NUT, SPINDLE AND BODY ARE SEIZING UP DUE TO GUNGE, LACK OF LUBRICATION AND/OR WEAR AND TEAR.
YES YOU UNDO THE FITTING BY UNSCREWING THE LARGE NUT, THEN YOU CAN EITHER CLEAN AND REPAIR OR REPLACE THIS ASSEMBLY.
(CHEAP ENOUGH TO BUY NEW).
ALDA.
rosebery
by rosebery » Fri May 09, 2008 3:36 pm
Yes I'd replace the whole thing (its called the valve head by the way). Only a couple of quid.
Kenny123
thanks
by Kenny123 » Fri May 09, 2008 6:26 pm
nice one mate, i'll give it a go! do i need to turn cold water supply of first to remove hot water spindle as it's a mixer tap?
thanks again for the reply....
Kenny ;o)
It is currently Fri Jan 24, 2025 7:31 am
