Removing sheared screws
HobNob
by HobNob » Mon May 12, 2008 9:13 am
How can I remove screws from an old wooded door where the heads have sheared off?
Any advice gratefully received.
ALDA
by ALDA » Mon May 12, 2008 9:27 pm
HN,
THIS WILL PROVE DIFFICULT TO DO WITHOUT DAMAGING THE DOOR SURFACE BUT CAN BE FILLED AND SANDED LATER.
TRY USING A LEATHER WORKER'S HOLE PUNCH AND/OR HALF ROUND WOOD CHISEL TO REMOVE A RING OF WOOD AROUND THE SHEARED SCREW SUFFICIENTLY TO ALLOW YOU TO GRIP THE SCREW WITH PLIERS OR MOLE GRIPS TO REMOVE.
ALDA.
chris_on_tour2002
by chris_on_tour2002 » Thu May 15, 2008 11:24 am
you could drill them out using a quality drill bit suitable for steel. centre punch the screw first to prevent the bit from slipping.
HobNob
by HobNob » Fri May 16, 2008 11:23 am
Many thanks for the suggestions.
It is currently Tue Jan 07, 2025 11:44 pm
