Hardcore, what can I use
boowee
by boowee » Mon May 12, 2008 3:28 pm
I am digging out and intending to lay a new patio, and understand that on my type of clay soil an amount of well compacted hardcore is required.
What can I use as hardcore and where can I get some, it's not the easist of words to research on the net.
Any help would be most appreciated.
censored
by welsh brickie » Mon May 12, 2008 7:56 pm
never heard of it.
Hardcore is what you require its quarry waste or sometimes called
crush&run.
You will need to lay it about 50mm thick or more if required and compact it with a plate vibrator, thats the best way to create a firm base for your slabs.
All builders merchants supply it they will usually quantify how much you require and deliver.
rosebery
by rosebery » Mon May 12, 2008 11:33 pm
If you spell the word h a r d c o r e out with spaces in between the letters then the forum censor won't treat it as being rude!
Then everyone will understand it.
stevenc1603
by stevenc1603 » Tue May 13, 2008 12:24 pm
If you go to your local builders merchant or quarry and ask for type1 then you should find what you are after.
It is currently Wed Jan 15, 2025 12:51 pm
