Lights supplied from fcu
Basil20
by Basil20 » Mon May 12, 2008 9:29 pm
I have just built in two separate walk in wardrobes in my new loft conversion and would like to put lights inside them,
i would like to know if i can take a spur from a socket to a fused connection unit, then take a 1.0mm cable from the load to a light pendant with switch cable to a switch, then take a 1.0mm cable from light pendant to the second wardrobe to supply light and switch, can someone tell me if this is o.k and if so which fuse to use 3 or 5 amp.
Thanks in advance for any info.
by ericmark » Mon May 12, 2008 9:51 pm
Seems OK to me. But I would use cold lighting LED or energy saving or it may set cloths on fire. And with that type of bulb a 1 amp fuse is enough.
It is currently Sun Nov 24, 2024 1:32 am
