Foundation help
Respect1001
Foundation help
by Respect1001 » Sun Apr 29, 2007 3:34 pm
I have water and gas pipes running through my foundations. Please can someone tell me the best way to bridge them with lintels and a step by step guide how to do it.
Many Thanks
Simon
thedoctor
by thedoctor » Sat May 12, 2007 12:07 pm
If they are actually running through the concrete of the foundations they can be ducted through with circular drain pipes of a slightly larger diameter than the pipe. This will not affect the integrity of the foundation. If the pipes need to go through the brickwork etc a lintel should be put in over the hole and it should have a minimum of 150mm bearing either side of the hole.
It is currently Wed Jan 22, 2025 1:48 am
