Emersion re-siteing
8 posts   •   Page 1 of 1
Karlos
Emersion re-siteing
by Karlos » Tue May 13, 2008 11:33 pm
[color=red][b] I am thinking of moving my emersion heater from the kitchen to the bathroom up stairs will expect any problems with presure and what size pipe should i use plastic or copper :?: [/b]
nitro23456
by nitro23456 » Wed May 14, 2008 9:45 am
I use copper.
by htg engineer » Wed May 14, 2008 8:31 pm
Is this a tank, only heated by the immersion ?
or is it heated by a boiler too ?
The hot water draw off, normally 22mm copper
mains cold water 15mm copper.
If it's connected to a boiler, 28mm copper.
You also need to install an overflow, normally 22mm plastic.
What does the immersion supply hot water to ? just the kitchen ? (as the bathroom is upstairs) ?
htg
Karlos
by Karlos » Wed May 14, 2008 10:52 pm
[quote="htg engineer"]Is this a tank, only heated by the immersion ?
htg[/quote]the tank is only heated by the immersion and will provide hot water for both kitchen and bathroom as it does now. I am re-siteing to make way for eyeleval oven there is plent of room behind the bath tub to put an airing cubboard and house the tank .
Karlos
by Karlos » Wed May 14, 2008 10:57 pm
:!: The tank is only heated by the immersion and provides hot water for both kitchen and bathroom. i am re-siteing be hind the bath tub to make way for eye level oven
plumbbob
by plumbbob » Thu May 15, 2008 8:28 am
Normally on a low pressure system, feeds to sinks and basins are 15mm and the 22mm to a bath. The existing pie sizes should give you a good clue as to what are required.
Just be aware, the electrical work needs, under the new regulations, to be done by a qualified electrician.
chris_on_tour2002
by chris_on_tour2002 » Thu May 15, 2008 11:16 am
do you intend to feed from the main or from a tank in the loft? if mains then should be no problem with pressure. if it was feeding the bathroom before with no problem then it should in theory work better if you move it upstairs.
Karlos
by Karlos » Sun May 18, 2008 8:04 pm
Hey thanks guys :)
It is currently Sun Nov 24, 2024 6:54 am
