Double Glazing sealant
DaveS
by DaveS » Thu May 15, 2008 9:04 am
In a house full of smokers the sealant or adhesive used around the frames has yellowed over time. I could redo it, but the installer was a bit (a lot) untidy with the stuff and I need to remove the excess before starting work. Is there a solvent that will do this? It doesn't appear to be silicon since it's dried hard. Any ideas on the type of sealant/adhesive used? Failing that, is it practical to buy some quarter-round upvc strip to cover the old stuff up completely? And if so where could I source this?
sealant
by welsh brickie » Thu May 15, 2008 1:26 pm
it sounds like he has used decorators caulk.
Its probably going to be a better job to cover whats there so I would
suggest using small quad ,you can get it at a plastic suppliers, or d,glazing
companys will sell it, or recomend a supplier who can help you.
It is currently Sun Dec 22, 2024 6:47 pm
