maintenance of flat roof
Barum
by Barum » Sun May 18, 2008 5:46 pm
My flat roof was covered 5 years ago... no problems, but I would lik to make sure it will last longer....can I put any liquid solution over it so that any possible cracks will be covered before the summer sun gets at it ?
or are there any other precautions I can take to extend its life ? thankyou
Favposi
by Favposi » Sat Oct 11, 2008 1:15 am
If your not having any problems at the moment with the roof, as the old saying goes, "Why fix it if it isn't broke".
Flat roofs leaks can be expensive to fix unless there are obvious signs of the leak, ie crack in the felt.
As a temporary measure, if you find a crack in the felt you could use a liquid product called Acrypol.
It is currently Tue Nov 26, 2024 3:50 am
