bathroom hot tap now on low constant flow
banks
by banks » Mon Apr 30, 2007 6:29 am
I have read the very helpful project page but worried that even when I turn off the water because I am working on hot tap upstairs that water will still come out as it is attached to a tank? will this be the case? we have soft water so assume that it will just need a washer change?
cueball
by cueball » Tue May 01, 2007 11:23 pm
yes, tap will run for a while until water level in cylinder = tap level. Shutting off gate valve on cylinder feed from cold cistern will speed this up, or better still service valve near tap if you have one.
It is currently Fri Nov 22, 2024 10:34 pm
