We have a Gloworm Ultimate Central Heating System that has a Lifestyle LP241 control panel, having problems... not sure if anyone can help?
You can turn the water and heating on and off independently using the control panel. At the moment it is switched to only heating the water. BUT it is also heating the radiators as well.
We have had the valve replaced in the boiler but that has not fixed the problem.
Has anyone else had this problem?
Thanks in advance.
