by Monkey Magic »
Wed May 21, 2008 8:25 pm
Hi Ericmark,
Thanks for the terrific answer, it helped to understand the history of why the different ratings.
I don't doubt my mates abilities but the new cu fitted is a Wylex 17th ed version with twin rcd's, one rated 80a/30mA and the other 63a/30mA which he's used as a matter of course.
Thing is I reckon the 63a probably isnt enough as it looks after upstairs lights 6a, bathroom lights 6a, downstairs ring 32a, kitchen ring 32a and the shower 40a is on there as well, so even allowing for diversity I wasn't too sure.
The 80a looks after immersion heater 16a, downstairs lights 6a, cooker 40a, shower room lights 6a, upstairs new extension ring 32a and then there is the boiler 16a rcbo and 6a rcbo for the smokes on the switch side.
Bearing in mind what you have said, do you think it would be better to change the 63a rcd for a 100a rated? If so does it matter that the 80a rcd would be closer to the DP main switch than the 100a rated?
Wow, I think I've just surprised myself with all that!!
Thanks for your help and knowledge, much appreciated.
Regards
MM
