limited hot water
Hairypete
limited hot water
by Hairypete » Tue May 20, 2008 4:46 pm
My boiler is currently bust so I'm relying on my immersion heater. It works but gives only enough water for washing up bowl, but not enough for a bath. Any ideas? I've already replaced the immersion element to no avail.
plumbbob
by plumbbob » Tue May 20, 2008 8:55 pm
This all depends on the size of tank you have, and how long an element you fitted. Elements come in two lengths. Did you replace a short one with another???
Hairypete
by Hairypete » Wed Jun 18, 2008 11:26 pm
sorry for delay - problems with internet!
Yes I replaced the element with a short one, identical to the one I removed.
plumbbob
by plumbbob » Thu Jun 19, 2008 9:39 am
It seems reasonable the element you have fitted is too short for the tank. A short immersion will only heat the top few inches of water, hence the you only get a bowl full of hot water.
[url]http://www.awin1.com/awclick.php?mid=1228&id=61071&p=http://www.screwfix.com/prods/63692/Plumbing/Hot-Water-Cylinders/Resettable-Long-Life-Immersion-Heater-27 [/url]
It is currently Fri Jan 10, 2025 9:24 am
