power flow
redkev
power flow
by redkev » Wed May 21, 2008 10:57 pm
i have just purchased a kamco machine. my house pipes are all black and im going to use the machine on them. obviously i have located the heating tank in the loft. is it just a case of blanking the clod feed and the expansion?
Rico
by Rico » Thu May 22, 2008 9:57 am
Kev,
Have you been on the Kamco training course. If not I suggest you do.
Its a free 1 day course at the hq in St Albans. It really does make sense before doing this yourself.
If you dont even know what you need to do with the f&e tank then I suggest you dont tackle this yourself at the moment.
Rico
by htg engineer » Thu May 22, 2008 11:51 am
"my house pipes are all black and im going to use the machine on them"
the pipes are black ??? how do you know, have you taken them out anc checked ?
is the water black ?
what problems have you had with your system ? for a powerflush to be required ?
Pressurised system ? if not - get it wrong you could end up needing a whole new system.
redkev
by redkev » Mon May 26, 2008 8:42 pm
the reason i want to do it is that when i took a radiator off to paper behind it the colour of the water inside the radiator was black so i would just like to clean it out. i have used the machine on a combi system and u just take off one radiator and connect to flow and return.
i would just like to know how it is done when u have a heating tank. i would presume you would blank the cold feed and the expansion! is this correct? cheers
It is currently Mon Nov 25, 2024 8:19 pm
