Combi Boiler condensate and PRV connections
Duncan Jackson
by Duncan Jackson » Thu May 22, 2008 10:53 am
Can the condensate and PRV be piped into the same waste connection, say standard 40mm white/black kitchen waste pipe in an upstand arrangement.
The condensate on my boiler appears to be a small c.10mm push on connection to recieve some type of plastic hose. Manual says this is to be run in min 21mm dia waste pipe so assume I just insert it in to the pipe which runs at a substantial fall (as per the manual).
Is it common on new combi boilersto have a buitl in filling loop.
Duncan
It is currently Thu Jan 09, 2025 6:54 pm
