Black Plastic Cold Water Header Tanks...
cloggsy
by cloggsy » Mon Apr 30, 2007 5:40 pm
Hello,
I dunno if this is the correct place to ask, but I'm after some used black plastic header tanks with lids... Ideally, I need 3!
I don't mind if they have pipe holes in as you can buy plugs to close the holes up...
I'm after tanks with an approximate size of 500mm wide x 500mm tall x 800mm long (or there about...)
Can anyone help at all?
thedoctor
by thedoctor » Mon Apr 30, 2007 8:15 pm
See the projects section and look at cheap building materials
It is currently Sun Dec 22, 2024 6:25 pm
